TDA955X引脚功能含义
定义       脚号    定义详解
P1.3/T1     01 port 1.3 计数器/定时器1输入
P1.6/SCL    02 port 1.6 I2C总线时钟线
P1.7/SDA    03 port 1.7 I2C总线数据线
P2.0/TPWM   04 port 2.0 梯形波脉宽调制
P3.0/ADC0   05 port 3.0 ADC0 输入
P3.1/ADC1   06 port 3.1 ADC1 输入
P3.2/ADC2   07 port 3.2 ADC2 输入
P3.3/ADC3   08 port 3.3 ADC3 输入
VSSC/P      09 数字地面m-controller核心与外围
P0.5        10 port 0.5 (8毫安电流驱动发光指示灯)
P0.6        11 port 0.6 (8毫安电流驱动发光指示灯)
VSSA        12 tv-processor图文电视解码器
SECPLL      13 制式锁相环
VP2         14 电源电压 (+8V)
DECDIG      15 数字电路的电源电压
PH2LF       16 滤波器2
PH1LF       17 滤波器1
GND3        18 ground 3 for TV-processor
DECBG       19 bandgap decoupling
AVL/EW      20 自动调平 (90° versions) / E-W drive output
VDRB        21 vertical drive B output
VDRA        22 vertical drive A output
IFIN1       23 IF input 1
IFIN2       24 IF input 2
IREF        25 reference current input
VSC         26 vertical sawtooth capacitor
AGCOUT      27 调谐器自动增益控制输出
AUD/SIF     28 audio deemphasis or SIF input 1
DEC/SIF     29 decoupling sound demodulator or SIF input 2
GND2        30 ground 2 for TV processor
PLL/SIF     31 narrow band PLL filter or AGC sound IF
AVL/SNDIF   32 Automatic Volume Levelling / sound IF input / subcarrier reference
HOUT        33 horizontal output
FBISO       34 flyback input/sandcastle output
AUDEXT/QSSO 35 external audio output / QSS intercarrier out / AM audio output
EHTO        36 EHT/overvoltage protection input
PLLIF       37 IF-PLL loop filter
IFVO/SVO    38 IF video output / selected CVBS output
VP1         39 supply voltage TV processor
CVBS1       40 internal CVBS input
GND         41 ground for TV processor
CVBS/Y      42 CVBS/Y input
C           43 C input
AUD/AMOUT   44 audio output /AM audio output (volume controlled)
INSSW2      45 2nd RGB / YUV insertion input
R2/VIN      46 2nd R input / V (R-Y) input / PR input
G2/YIN      47 2nd G input / Y input
B2/UIN      48 2nd B input / U (B-Y) input / PB input
BCLIN       49 beam current limiter input
BLKIN       50 black current input / V-guard input
RO          51 Red output
GO          52 Green output
BO          53 Blue output
VDDA        54 数字解码器电源 (3.3 V)
VPE         55 OTP Programming Voltage
VDDC        56 数字电源 (3.3 V)
OSCGND      57 oscillator ground supply
XTALIN      58 crystal oscillator input
XTALOUT     59 crystal oscillator output
RESET       60 reseV
VDDP        61 digital supply to periphery (+3.3 V)
P1.0/INT1   62 port 1.0 or external interrupt 1 input
P1.1/T0     63 port 1.1 or Counter/Timer 0 input [Page]
P1.2/INT0   64 port 1.2 or external interrupt 0 input
飞利浦TDA955X内部方框图
TDA955X芯片外围功能图
