显示驱动
LM3914 10-Step Dot/Bar显示驱动器, Linear scale [366KB]
LM3915 10-Step Dot/Bar显示驱动器, Logarithmic scale [602KB]
LM3916 10-Step Dot/Bar显示驱动器 [509KB]
UAA180 LED driver Light or light spot display operation for max. 12 emitting
diodes [88KB]
CA3161E BCD to Seven Segment Decoder/Driver [68KB]
CA3162E A/D Converter for 3-Digit Display [522KB]
ICL7136 3 1/2 Digit LCD, Low Power Display, A/D Converter [406kb]
PLL 立体声解码
LM1800 PLL Stereo Decoder [NTE743][25KB]
CA3090P Stereo Multiplex Decoder (Comp.to NTE789 From NTE)[33KB]
MC1310P FM Stereo Demodulator (Comp. to NTE801 From NTE)[20KB]
定时-时钟电路
555 时钟[111kb]
556 双 555 [96kb]
MN3101 时钟/ 驱动[562kb]
XR2206 Monolithic Function Generator [192KB]
光电耦合
4N25 6-PIN 光电晶体管 OPTOCOUPLERS [156KB]
4N26
4N27
4N28
4N35 6-PIN 光电晶体管 OPTOCOUPLERS [152KB]
4N36
4N37
H11A1 OPTICALLY COUPLED ISOLATORS
H11A2
H11A3
SCR - TRIAC
BTY79-800R 硅 Controlled Rectifier 25A[NTE5531][19KB]
C106D 硅 Controlled Rectifier 4A [52KB]
时钟
MM5314N Clock Alarm chip from National Semiconductor Html
