二极管
1N4000 系列 1 Amp. 硅 Rectifier Diodes (1A) [39kb]
1N4148 Small-Signal Diode (100mA) [169kb]
1N5408 General Purpose Plastic Rectifier (3A) [54kb]
IN5236B 7.6V 0.5W Zener Voltage Regulator Diode [84kb]
1N5240B 10V 0.5W Zener Voltage Regulator Diode [84kb]
1N5252B 24V 0.5W Zener Voltage Regulator Diode [84kb]
电子管
300B Power 真空三极管 intended for use in class A, AB or B 音频 amplifiers.
[52KB]
5U4G TUBE Rectifier [335KB]
6SN7 双 真空三极管 [65KB]
6BX7 GT 双 真空三极管 [335 kb]
6DJ8 小信号 双 真空三极管 intended for line-level amp. or driver similar to
ECC88 [180KB]
6N1P 小信号 双 真空三极管 intended for line-level amp. or driver similar to
ECC88 [180KB]
6922 小信号 双 真空三极管 intended for line-level amp. or driver similar to
ECC88 [637 kB ]
12AT7 A.F. 双 真空三极管 similar to ECC81 [356KB]
12AU7 A.F. 双 真空三极管 similar to ECC82 [434KB]
12AX7 A.F. 双 真空三极管 similar to ECC83 [292 kB]
E80CC 双 真空三极管 for A.F DC amplifiers [279 Kb]
ECC81 A.F. 双 真空三极管 similar to 12AT7 [97KB]
ECC82 A.F. 双 真空三极管 similar to 12AU7 [94KB]
ECC83 A.F. 双 真空三极管 similar to 12AX7 [92KB]
ECC88 小信号 双 真空三极管 similar to 6922, 691P, 6DJ8 [180KB]
EL34 High Power penthode [504KB]
EL84 High Power A.F output Pentode [392 kb]
Z2C TUBE Rectifier [52Kb]
KT88 Power Tetrode for output stage of AF amplifier [435 kb
