概述:8809CSBNG4H99是一款双列密64脚封装。
引脚功能和电压参数值
脚号 | 符号 | 有信号电压/V | 黑笔接地电阻/KΩ | 红笔接地电阻/KΩ | 功能说明 |
1 | SVIDEO | 4.6 | 7 | 11 | S端子亮度输入 |
2 | MUTE | 0 | 7 | 11 | 静音输出 |
3 | KEY in | 0.3 | 7 | 9.4 | 按键矩阵输入 |
4 | UP Dvss | 0 | 0 | 0 | 接地端 |
5 | RESET | 4.8 | 4.6 | 4.6 | 复位脚 |
6 | X in | 2.1 | 7.7 | 12.2 | 晶振输入 |
7 | X out | 0.9 | 7.7 | 12.2 | 晶振输出 |
8 | TEST | 0 | 0 | 0 | 测试脚 |
9 | UP Dvvd | 4.8 | 2.2 | 2.2 | +5V供电 |
10 | UP Dvss | 0 | 0 | 0 | 接地脚 |
11 | TV AGND | 0 | 0 | 0 | 接地脚 |
12 | FBP | 1 | 1 | 27.8 | 回扫脉冲输入 |
13 | Hout | 1.8 | 1.8 | 0.5 | 行激励输出端 |
14 | HAFC | 6.4 | 6.4 | +∞ | 行同步信号分离滤波 |
15 | VSAW | 4 | 4 | 27.5 | 常锯齿波滤波端 |
16 | Vout | 4.6 | 4.6 | 13.5 | 场激励输出端 |
17 | HvCC | 9.2 | 9.2 | 9.1 | 行启动电源 |
18 | NC | 0.9 | 0.9 | 0.8 | 空脚 |
19 | Cb in | 9.9 | 9.9 | 13 | B-Y信号输入 |
20 | Y in | 9.7 | 9.7 | 13 | Y信号输入端 |
21 | Cr in | 9.9 | 9.9 | 12.8 | R-Y信号输入端 |
22 | VD AND | 0 | 0 | 0 | 接地端 |
23 | C in | 9.8 | 9.8 | 12.8 | 色度信号输入端 |
24 | V2 in | 9.8 | 9.8 | 12.8 | 视频2信号输入端 |
25 | TV DVcc | 3.4 | 3.4 | 9.1 | 罗辑电源端 |
26 | VI in | 2 | 2 | 12.8 | 视频输入端 |
27 | ABCL | 3.8 | 3.8 | 12 | 自动亮度色度控制端 |
28 | AU out | 3.4 | 3.4 | 11 | 音频信号输出端 |
29 | IF Vcc | 8.7 | 8.7 | 0.3 | 中频+9V供电端 |
30 | TV out | 3.5 | 3.5 | 10.2 | 视频信号输出端 |
31 | SIF out | 1.8 | 1.8 | 13 | 伴音信号输出端 |
32 | EXT AU in | 3.1 | 10 | 12 | 外部音频信号输入端 |
33 | SIF in | 2.1 | 9.5 | 13 | 伴音信号输入端 |
34 | DC NF | 2 | 9.9 | 12 | 直流负反馈外接电容 |
35 | PIF PLL | 2.4 | 9.9 | 12.8 | PIF锁相环 |
36 | IF Vcc | 4.4 | 0.8 | 0.8 | +5V供电脚(IF) |
37 | Reg Fil | 2 | 9.5 | 11 | 外接电容滤波端 |
38 | Deempha | 4.2 | 9.7 | 12 | SIF去加重 |
39 | IF AGC | 1.5 | 9.8 | 12.8 | IF AGC滤波 |
40 | IF GND | 0 | 0 | 0 | 接地端(IF) |
41 | IF in | 0 | 9 | 12.2 | 中频信号输入 |
42 | IF in | 0 | 9 | 12.2 | 中频信号输入 |
43 | RF AGC | 1.6 | 9.5 | 11.2 | RI AGC输出端 |
44 | TV YC VCC | 4.4 | 0.8 | 0.8 | +5V供电端 |
45 | Monitoy out | 1.7 | 3 | 3 | 监测输出 |
46 | BLACK DET | 2.4 | 10 | 12.5 | 黑电平检波 |
47 | Chroma PLL | 1.7 | 9.9 | 13 | 彩色锁相环 |
48 | IK in | 0 | 0 | 0 | 阴极检测电流输入端 |
49 | RGB Vcc | 8.7 | 0..3 | 0.3 | R G B电源 |
50 | Rout | 2.5 | 9.7 | 9.8 | 红基色信号输出 |
51 | Gout | 2.5 | 9.7 | 9.8 | 绿基色信号输出 |
52 | Bout | 2.5 | 9.7 | 9.8 | 蓝基色信号输出 |
53 | TV AGND | 0 | 0 | 0 | 接地端 |
54 | UP AGND | 0 | 0 | 0 | 接地脚 |
55 | UP AVdd | 4.8 | 2.2 | 2.2 | +5V供电 |
56 | BAND | 4.8 | 5.6 | 6 | 波段控制 |
57 | SDA | 4.6 | 6.2 | 10.8 | I2C串行数据入/出 |
58 | SCL | 4.6 | 6.8 | 10.8 | I2C串行数据入/出 |
59 | VOL | 2.3 | 2.2 | 2.4 | 音量控制 |
60 | VT | 4.6 | 7.5 | 11.8 | 调谐控制输出 |
61 | BAND | 0.1 | 5 | 5.1 | 波段控制1 |
62 | HSYNC | 3.4 | 7.4 | 11.2 | 行同步脉冲输入 |
63 | RMT in | 4.2 | 7.2 | 12 | 遥控信号输入 |
64 | power | 0.1 | 3.4 | 3.5 | 电源待机控制输出 |
