长虹CN-11机芯
该机芯所用CPU为CHT0608,其代表产品有PF29E8、PF29E18、PF25E8、PF29E6等型号,该机芯总线总线调试方法:按住本机菜单键,再按遥控器输入“5、1、9、8”即可进入维修状态。进入维修调试状态后,按遥控器上的“日历”键、“S”降噪键、“菜单”键进行翻项,按频道加、减键翻頁,按音量加、减键改变参数大小。现列出G29E6彩电数据参数。
表(25)
按“S”键 | 按日历键 | ||||
项目 | 参考值 | 备注 | 项目 | 参考值 | 备注 |
VAMP | 23 | 场幅 | SCOLOR P | 3A | |
V50 | 03 | 50场中心 | SCOLOR N | 35 | |
V60 | 03 | 60场中心 | SCOLOR S | 1F | |
SCR | 05 | S校正 | STINT | OB | |
CCR | 01 | 场线性 | SBRIGHT | 7F | |
WID | 11 | 行幅 | SCONTRAST | 3F | |
EWC | 17 | 东西校正 | SSHARP | 26 | |
CNR | 02 | 四角校正 | CUT OFF R | C2 | |
TRAP | -00 | 梯形校正 | CUT OFF G | E2 | |
ZMOD | 00 | CUT OFF B | C7 | ||
ZAMP | 00 | SECAM CUR | 00 | ||
TC DATA1 | 78 | SECAM CUG | 00 | ||
TC DATA2 | 01 | DRIVE R | 4D | ||
TC DATA3 | 0B | DRIVE B | 4A | ||
菜单键 | RFAGC | 26 | |||
SECAM | NO(YES) | SECAM功能设定 | HOR POS | 11 | |
TEL | NO(YES) | 图文功能 | AFT | 4B | |
NIC | NO(YES) | 丽音功能 | IF.VCO | 1C | |
DCOMB | NO(YES) | 梳状功能 | TEMP | 02 | |
HAP | YES(N0) | 红双喜显示 | HOR.VCO | 4C | |
KA22686 | N0 | 环绕声设定 | VIF DL NEG | 1C | |
S VIEW | NO | BBE模式设定 | VIF DL POI | 00 | |
WOOFER | NO(YES) | 重低音功能 | VIF DL POE | 7F | |
SCREEN SIZE | BIG(SMALL) | 屏幕大小设定 | SIF DL M | 09 | |
COL | EWROPE(EUROPE) | 彩色检波 | SIF DL BG | 08 | |
DCOMB CTR | IISBUS(PORT) | 梳状滤波控制 | SIF DL I | 07 | |
SHARP PEAK | 3M | 清晰度设定 | SIF DL DK | 07 | DK制伴音检波 |
TV NTSC | YES(NO) | TV N制功能 | VER POS | 03 | |
SIF SW | INT(EXT) | 内外伴音开关设定 | VER HEIGHT | 0E | |
PAL-M/N | NO | PAL-M/N制功能 | V.LINE AR50 | 36 | |
SAW | QSS(INT) | 声表面滤波器选择 | V.LINE AR60 | 3E | |
AV NUM | 3AV(2AV) | AV路数设定 | VER.SCURVE | 20 | |
ONE AV | OTHER(ONE) | Y TV SECAM | 00 | ||
Y TV 358 | 00 | ||||
Y TV 443 | 00 | ||||
SIF BW M | 00 | ||||
SIF BW BG | 00 | ||||
SIF BW I | 03 | ||||
SIF BW DK | 02 | DK制伴音滤波 | |||
SIF TP M | 0A | ||||
SIF TP BG | 06 | ||||
SIF TP I | 05 | ||||
SIF TP DK | 03 | DK制伴音陷波 | |||
SIF TP2 M | 0B | ||||
SIF TP2 BG | 0B | ||||
SIF TP2 I | 0B | ||||
SIF TP2 DK | 0B | DK制陷波宽度 | |||
SECAM BL | 30 | ||||
RGB LIMIT | 00 |
