通用部分
广播
 broadcasting
 节目输入设备
 programme input equipment
电视
 television
 广播网络
 broadcasting network
无线电视
 radio broadcasting
 控制室
 control room
有线广播
 wired broadcasting
 制作控制室
 production control room
卫星广播
 satellite broadcasting
 监测
 monitor (to)
声音广播
 sound broadcasting
 电平监测
 level monitoring
电视广播
 television broadcasting
 提示指令
 cue
调幅广播
 AM broadcasting
 混合
 mix (to)
调频广播
 FM broadcasting
 闭路
 closed circuit
实况广播
 live broadcast
 节目信号线
 programme line
直播
 direct broadcast
 峰值音量表
 peak programme meter
录播
 recorded broadcast
 听觉加权网络
 aural sensitivity network
节目信号
 programme signal
 源信号
 source signal
电视广播通用部分
电视
 television
 兼容性
 compatibility
黑白电视
 black-white television
menochrome television
 NTSC制彩色电视
 NTSC colour
television system
彩色电视
 colour television
 PAL制彩色电视
 PAL colour
television system
电视制式
 television system
 SECAM制彩色电视
 SECAM colour
television system
电视标准
 television standard
 亮度通道
 luminance channel
扫描
 scanning
 亮度陷波
 luminance notch
Kell系数
 Kell factor
 色度通道
 chrominance channel
扫描点
 scanning spot
 色度
 chrominance
扫描速度
 scanning speed
 色度分量
 chrominance components
扫描行
 scanning line
 色度轴
 chrominance axis
光栅
 raster
 色度基色
 chrominance primary
行频
 line frequency
 亮度轴
 luminance axis
逐行扫描
 sequential scanning
 亮度基色
 luminance primary
隔行扫描
 interlaced scanning
 亮度系数
 luminance coefficients
隔点扫描
 dot interlaced scanning
 零相位基准
 zero phase reference
帧频
 frame frequency
 传送基色
 transmission primaries
 field
 分辨率匹配
 acuity matching
场频
 field frequency
 显示基色
 display primaries
同步
 synchronism
 色坐标变换
 colour coordinate transformation
正程
 trace
 立体电视
 stereoscopic television
  [Page]
逆程
 flyback,retrace
 高清晰电视
 HDTV (high definition television)
同步传声
 sound-in sync
 共用天线电视(CATV)
 CATV(common antenna television)
伴音蜂音
 buzz-on-sound,
intercarrier buzz
 有线电视
 CATV (cable television)
顺序制彩色电视
 sequential colour television
 图文电视
 teletext
同时制彩色电视
 simultaneous colour television
 静止图象广播
 still picture broadcasting
恒定亮度传送
 constant luminance transmission
 多路伴音电视
 TV with multi-channel sound
电视广播视觉与图像质量
图像
 行(场)非线性
 line(field)non-linearity
像素
 picture element,pixel(pel)
 图像滑动
 picture slip
宽高比
 aspect ratio
 (图像)撕裂
 tearing
清晰度(分辨力)
 definition
 锯齿失真
 serration
分辨力
 resolution
 图像滚动
 picture roll
孔阑校正
 aperture correction
 (图像)晃动
 jitter
余晖失真
 aferglow distortion
 成帧
 framing
亮度
 luminance
 (画面)胀缩
 breathing
对比度
 contrast ratio
 画框
 safearea
γ(伽马)
 gamma
 亮度闪烁
 luminance flicker
γ校正
 gamma correction
 色度闪烁
 chromaticity flicker
灰度级
 grey scale
 彩色闪烁
 colour flicker
灰度级失真
 grey scale distortion
 彩色镶边
 colour fringing
底色失真
 shading
 颜色污染
 colour contamination
斑点
 stain
 亮串色
 cross-colour
模糊
 blurring
 亮串色杂波
 cross-colour noise
杂散光
 flare
 色纯度
 purity
拖尾
 streaking(smearing)
 标准白
 standard white
波纹干扰
 moire
 参考白
 reference white
浮雕效应
 plastic effect(relief effect)
 白色光轨迹
 achromatic locus
并行现象
 pairing,twinning
 灰度级跟踪
 grey scale tracking
重影,多重影
 ghost,multiple image
 行蠕动(爬行)
 line crawl,venetian-blind effect
阻尼振荡
 ringing
 光点图样
 dot pattern
过白?
 whiter than white
 点整流
 dot rectification
杂波
 noise
 视觉惰性
 visual persistence,persistence
交流声条
 hum bars
 适应性
 adaptability
几何失真
 geometrical distorition
电视广播信号及其特性
彩色图像信号
 colour picture signal
 插入测试信号
 insertion test signal(ITS) [Page]
同步信号
 synchronizing signal
 场同步信号
 field synchronizing signal、
色同步信号
 colour burst
 齿脉冲
 serration pulse,broad pulse
全电视信号
 composite signal
 均衡脉冲
 equalizing pulse
视频信号
 video signal
 行(场)推动信号
 line(field)drive signal
视频频带
 video frequency band
 伴音载频
 sound carrier frequency
已调图像信号
 modulated vision signal
 图像载频
 vision carrier frequency
消隐
 blanking
 行时间波形失真
 line time distortion
消隐电平
 blanking level
 场时间波形失真
 field time distortion
黑电平
 black level
 亮度信号
 luminance signal
同步电平
 sync level
 亮度差值信号
 luminance difference signal
白电平
 white level
 色度信号
 chrominance signal
同步峰值
 peak sync
 混合高频分量
 mixed highs
峰值白电平
 peak white
 U 信号
 U signal
平均图像电平
 average picture-signal level(APL)
 V 信号
 V signal
消隐台阶
 pedestal lift
 色差信号
 colour difference signal
图像直流分量
 d.c.component
 色度副载波、
 chrominance subcarrier,
钳位脉冲
 clamping pulse
 三基色信号
 tristimulus signal
黑电平漂移
 black level shift
 色度副载波基准、
 chrominance subcarrier reference,
行同步信号
 line synchronizing signal
 R、G、B黑电平
 R.G.B.black level
前肩
 front porch
 R、G、B峰值电平
 R.G.B.peak level
后肩
 back porch
 色同步信号门脉冲
 burst gating pulse
缓冲段
 breeze way
 色度-亮度时延差
 chrominance-luminance delay inequality,
消隐期间
 blanking interval
 色度-亮度增益差
 chrominance-luminance gain inequality
行消隐期间
 line blanking period
 微分增益
 differential gain
行正程期间
 active line period
 微分相位
 differential phase
场消隐期间 field blanking interval 正交串扰 quadrature crosstalk
电视广播技术
正(负)极性
振幅调制
 positive(negative)
amplitude modulation
 台从锁相
 genlock (to)
直流传送
 d.c. transmission
 台主锁相
 slavelock (to)
交流传送
 a.c. transmission
 划变
 wipe
钳位
 clamping
 内键
 internal key(overlay)
直流恢复
 d.c. restoration [Page]
 外键
 external key(inlay)
黑电平校准
 black-level alignment
 色键
 chroma key
水平(垂直)
弓形校正
 horizontal (vertical)
bow correction
 白平衡
 white balance
水平(垂直)
梯形校正
keystone correction
 色同步消隐
 burst blanking
水平(垂直)
枕形/桶形校正
pincushion/barrel correction
 延迟线PAL(PAL-D)
标准PAL
 delay-line PAL(PAL-D),
standard PAL
行(场)锯齿
(抛物)校正
 horizontal(vertical)
sawtooth(parabolic correction
 锁相同步
 flywheel synchronization
杂散光校正
 flare correction
 定时
 timing
勾边
 crispening
 定相
 phasing
光点摆动
 spot wobble
 消磁
 degaussing
逆程消隐
 flyback blanking
 冻结
 freezing
载频偏置
 carrier-offset
 数字特技
 DVE(digital video effect)
内置波伴音方式
 intercarrier sound
 彩色校正
 colour masking
电视广播电视设备
显象管
 picture tube
 同步恢复器
 sync regenerator
投影电视机
 projection television receiver
 电视标准转换器
 television standers converter
磁带录象机
 video tape recorder
 制式转换器
 transcoder
电视电影设备
 telecine equipment
 屏幕分割开关
 split screen switch
电视影片
 telefilm
 三色摄象机
 trichromatic camera
电视接收机
 television receiver
 修饰滤色片
 trimming filter
摄象机信道
 camera channel
 分色镜、分色滤色器
 dichroic mirror, dichroic filter
电视摄象机
 television camera
 重合
 registration
摄象管
 camera tube
 总黑电平控制
 master black centrol
光影象
 optical image
 总增益控制
 master gain control
氧化铅摄象管
 plumbicon
 编码器
 coder
硅靶管
 silicon target camera tube
 色度调制器
 chrominance modulator
飞点扫描管
 flying spot tube
 三管彩色投影机
 trinoscope
光电阴极
 photo-cathode
 彩色编码器、解码器
 colour decoder , decoder
 target
 色度解调器
 chrominance demodulator
信号板
 signal plate
 消色器
 colour killer
偏转线圈
 deflection coils
 自动色度控制
 automatic chrominance control (ACC)
同步脉冲发生器
 sync pulse generator
 色饱和度控制
 saturation control ,colour intensity control
行[场]分频器 [Page]
 line (field) divider
 色调控制
 hue control
同步分离器
 sync separator
 彩色显象管
 colour picture tube
电子束开关管
 beam switching tube
 荫罩彩色显象管
 shadow-mask tube
色纯度控制磁铁
 colour purity magnet
 数字时基校正器
 digital time base corrector(DTBC)
会聚
 convergence
 帧存储器
 frame memory
静态会聚
 static convergence
 帧同步器
 frame synchronizer,
framestore synchronizer
动态会聚
 dynamic convergence
 数字式降噪器
 DNR (digital noise reducer
