可以从外网也可以从内网telnet到PIX上,从内网简单,不过从外网得作vpn,麻烦一些,也能用SSH 远程管理。
     从内网telnet:
     telnet 192.168.1.2 255.255.255.255 inside
     从外网telnet:
     Step 1 Set up IPSec by entering the following commands:
     isakmp policy 10 authentication pre-share
     isakmp policy 10 group 2
     isakmp enable outside
     crypto ipsec transform-set esp-des-md5 esp-des esp-md5-hmac
     crypto dynamic-map dynmap 10 set transform-set esp-des-md5
     crypto map mymap 10 ipsec-isakmp dynamic dynmap
     crypto map mymap interface outside
     Step 2 Set up an IP pool for the Telnet session by entering the following commands:
     ip local pool tnpool 1.1.1.1-1.1.1.1
     Step 3 Set up Telnet access by entering the following command:
     telnet 1.1.1.1 255.255.255.255 outside
     Step 4 Set up the VPN group for the remote Telnet user by entering the following commands:
     vpngroup telnet address-pool tnpool
     vpngroup telnet password 12345678
     sysopt connetion permit ipsec
     Step 5 Setup the VPN client authentication by entering the following commands:
     group telnet
     password 12345678
     现在就可以从cisco client上telnet。
