Saved
     PIX Version 6.3(1)
     interface ethernet0 auto 设定端口0 速率为自动
     interface ethernet1 100full 设定端口1 速率为100兆全双工
     interface ethernet2 auto 设定端口2 速率为自动
     nameif ethernet0 outside security0 设 定端口0 名称为 outside 安全级别为0
     nameif ethernet1 inside security100 设定端口1 名称为 inside 安全级别为100
     nameif ethernet2 dmz security50 设定端口2 名称为 dmz 安全级别为50
     enable password Dv0yXUGPM3Xt7xVs encrypted 特权密码
     passwd 2KFQnbNIdI.2KYOU encrypted 登陆密码
     hostname hhyy 设定防火墙名称
     fixup protocol ftp 21
     fixup protocol h323 h225 1720
     fixup protocol h323 ras 1718-1719
     fixup protocol http 80
     fixup protocol ils 389
     fixup protocol rsh 514
     fixup protocol rtsp 554
     fixup protocol sip 5060
     fixup protocol sip udp 5060
     no fixup protocol skinny 2000
     fixup protocol smtp 25
     fixup protocol sqlnet 1521
     允许用户查看、改变、启用或禁止一个服务或协议通过PIX防火墙,防火墙默认启用了一些常见的端口,但对于ORACLE等专有端口,需要专门启用。
     names
     access-list 101 permit ip 192.168.99.0 255.255.255.0 192.168.170.0 255.255.255.0
     access-list 101 permit ip 192.168.12.0 255.255.255.0 192.168.180.0 255.255.255.0
     access-list 101 permit ip 192.168.23.0 255.255.255.0 192.168.180.0 255.255.255.0
     access-list 101 permit ip 192.168.99.0 255.255.255.0 192.168.101.0 255.255.255.0
     建立访问列表,允许特定网段的地址访问某些网段
     access-list 120 deny icmp 192.168.2.0 255.255.255.0 any
     access-list 120 deny icmp 192.168.3.0 255.255.255.0 any
     access-list 120 deny icmp 192.168.4.0 255.255.255.0 any
     access-list 120 deny icmp 192.168.5.0 255.255.255.0 any
     access-list 120 deny icmp 192.168.6.0 255.255.255.0 any
     access-list 120 deny icmp 192.168.7.0 255.255.255.0 any
     access-list 120 deny icmp 192.168.8.0 255.255.255.0 any
     access-list 120 deny icmp 192.168.9.0 255.255.255.0 any
     access-list 120 deny icmp 192.168.10.0 255.255.255.0 any
     access-list 120 deny icmp 192.168.11.0 255.255.255.0 any
     access-list 120 deny icmp 192.168.12.0 255.255.255.0 any
     access-list 120 deny icmp 192.168.13.0 255.255.255.0 any
     access-list 120 deny icmp 192.168.14.0 255.255.255.0 any
     access-list 120 deny icmp 192.168.15.0 255.255.255.0 any
     access-list 120 deny icmp 192.168.16.0 255.255.255.0 any
     access-list 120 deny icmp 192.168.17.0 255.255.255.0 any
     access-list 120 deny icmp 192.168.18.0 255.255.255.0 any
     access-list 120 deny icmp 192.168.19.0 255.255.255.0 any
     access-list 120 deny icmp 192.168.20.0 255.255.255.0 any
     access-list 120 deny icmp 192.168.21.0 255.255.255.0 any
     access-list 120 deny icmp 192.168.22.0 255.255.255.0 any
     access-list 120 deny udp any any eq netbios-ns
     access-list 120 deny udp any any eq netbios-dgm
     access-list 120 deny udp any any eq 4444
     access-list 120 deny udp any any eq 1205
     access-list 120 deny udp any any eq 1209
     access-list 120 deny tcp any any eq 445
     access-list 120 deny tcp any any range 135 netbios-ssn
     access-list 120 permit ip any any
     建立访问列表120防止各个不同网段之间的ICMP发包及拒绝135、137等端口之间的通信(主要防止冲击波病毒)
     access-list 110 permit ip 192.168.99.0 255.255.255.0 192.168.101.0 255.255.255.0
     pager lines 24
     logging on
     logging monitor debugging
     logging buffered debugging
     logging trap notifications
     mtu outside 1500
     mtu inside 1500
     mtu dmz 1500
     ip address outside 10.1.1.4 255.255.255.224 设定外端口地址
     ip address inside 192.168.1.254 255.255.255.0 设定内端口地址
     ip address dmz 192.168.19.1 255.255.255.0 设定DMZ端口地址
     ip audit info action alarm
     ip audit attack action alarm
     ip local pool hhyy 192.168.170.1-192.168.170.254
     建立名称为hhyy的地址池,起始地址段为:192.168.170.1-192.168.170.254
     ip local pool yy 192.168.180.1-192.168.180.254
     建立名称为yy 的地址池,起始地址段为:192.168.180.1-192.168.180.254
     no failover
     failover timeout 0:00:00
     failover poll 15
     no failover ip address outside
     no failover ip address inside
     no failover ip address dmz
     no pdm history enable
     arp timeout 14400
   不支持故障切换
     global (outside) 1 10.1.1.13-10.1.1.28
     global (outside) 1 10.1.1.7-10.1.1.9
     global (outside) 1 10.1.1.10
     定义内部网络地址将要翻译成的全局地址或地址范围
     nat (inside) 0 access-list 101
     使得符合访问列表为101地址不通过翻译,对外部网络是可见的
     nat (inside) 1 192.168.0.0 255.255.0.0 0 0
     内部网络地址翻译成外部地址
     nat (dmz) 1 192.168.0.0 255.255.0.0 0 0
     DMZ区网络地址翻译成外部地址
     static (inside,outside) 10.1.1.5 192.168.12.100 netmask 255.255.255.255 0 0
     static (inside,outside) 10.1.1.12 192.168.12.158 netmask 255.255.255.255 0 0
     static (inside,outside) 10.1.1.3 192.168.2.4 netmask 255.255.255.255 0 0
     设定固定主机与外网固定IP之间的一对一静态转换
     static (dmz,outside) 10.1.1.2 192.168.19.2 netmask 255.255.255.255 0 0
     设定DMZ区固定主机与外网固定IP之间的一对一静态转换
     static (inside,dmz) 192.168.0.0 192.168.0.0 netmask 255.255.0.0 0 0
     设定内网固定主机与DMZ IP之间的一对一静态转换
     static (dmz,outside) 10.1.1.29 192.168.19.3 netmask 255.255.255.255 0 0
     access-group 120 in interface outside
     access-group 120 in interface inside
     access-group 120 in interface dmz
     将访问列表应用于端口
     conduit permit tcp host 10.1.1.2 any
     conduit permit tcp host 10.1.1.3 any
     conduit permit tcp host 10.1.1.12 any
     conduit permit tcp host 10.1.1.29 any
     设置管道:允许任何地址对全局地址进行TCP协议的访问
     conduit permit icmp 192.168.99.0 255.255.255.0 any
     设置管道:允许任何地址对192.168.99.0 255.255.255.0地址进行PING测试
     rip outside passive version 2
     rip inside passive version 2
     route outside 0.0.0.0 0.0.0.0 10.1.1.1
     设定默认路由到电信端
     route inside 192.168.2.0 255.255.255.0 192.168.1.1 1
     route inside 192.168.3.0 255.255.255.0 192.168.1.1 1
     route inside 192.168.4.0 255.255.255.0 192.168.1.1 1
     route inside 192.168.5.0 255.255.255.0 192.168.1.1 1
     route inside 192.168.6.0 255.255.255.0 192.168.1.1 1
     route inside 192.168.7.0 255.255.255.0 192.168.1.1 1
     route inside 192.168.8.0 255.255.255.0 192.168.1.1 1
     route inside 192.168.9.0 255.255.255.0 192.168.1.1 1
     route inside 192.168.10.0 255.255.255.0 192.168.1.1 1
     route inside 192.168.11.0 255.255.255.0 192.168.1.1 1
     设定路由回指到内部的子网
     timeout xlate 3:00:00
     timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
     1:00:00
     timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
     timeout uauth 0:05:00 absolute
     aaa-server TACACS+ protocol tacacs+
     aaa-server RADIUS protocol radius
     aaa-server LOCAL protocol local
     no snmp-server location
     no snmp-server contact
     snmp-server community public
     no snmp-server enable traps
     floodguard enable
     sysopt connection permit-ipsec
     sysopt connection permit-pptp
     service resetinbound
     service resetoutside
     crypto ipsec transform-set myset esp-des esp-md5-hmac
     定义一个名称为myset的交换集
     crypto dynamic-map dynmap 10 set transform-set myset
     根据myset交换集产生名称为dynmap的动态加密图集(可选)
     crypto map vpn 10 ipsec-isakmp dynamic dynmap
     将dynmap动态加密图集应用为IPSEC的策略模板(可选)
     crypto map vpn 20 ipsec-isakmp
     用IKE来建立IPSEC安全关联以保护由该加密条目指定的数据流
     crypto map vpn 20 match address 110
     为加密图指定列表110作为可匹配的列表
     crypto map vpn 20 set peer 10.1.1.41
     在加密图条目中指定IPSEC对等体
     crypto map vpn 20 set transform-set myset
     指定myset交换集可以被用于加密条目
     crypto map vpn client configuration address initiate
     指示PIX防火墙试图为每个对等体设置IP地址
     crypto map vpn client configuration address respond
     指示PIX防火墙接受来自任何请求对等体的IP地址请求
     crypto map vpn interface outside
     将加密图应用到外部接口
   isakmp enable outside
     在外部接口启用IKE协商
     isakmp key ******** address 10.1.1.41 netmask 255.255.255.255
     指定预共享密钥和远端对等体的地址
     isakmp identity address
     IKE身份设置成接口的IP地址
     isakmp client configuration address-pool local yy outside
     isakmp policy 10 authentication pre-share
     指定预共享密钥作为认证手段
     isakmp policy 10 encryption des
     指定56位DES作为将被用于IKE策略的加密算法
     isakmp policy 10 hash md5
     指定MD5 (HMAC变种)作为将被用于IKE策略的散列算法
     isakmp policy 10 group 2
     指定1024比特Diffie-Hellman组将被用于IKE策略
     isakmp policy 10 lifetime 86400
     每个安全关联的生存周期为86400秒(一天)
     vpngroup cisco idle-time 1800
     vpngroup pix_vpn address-pool yy
     vpngroup pix_vpn idle-time 1800
     vpngroup pix_vpn password ********
     vpngroup 123 address-pool yy
     vpngroup 123 idle-time 1800
     vpngroup 123 password ********
     vpngroup 456 address-pool yy
     vpngroup 456 idle-time 1800
     vpngroup 456 password ********
     telnet 192.168.88.144 255.255.255.255 inside
     telnet 192.168.88.154 255.255.255.255 inside
     telnet timeout 5
     ssh timeout 5
     console timeout 0
     vpdn group 1 accept dialin pptp
     vpdn group 1 ppp authentication pap
     vpdn group 1 ppp authentication chap
     vpdn group 1 ppp authentication mschap
     vpdn group 1 ppp encryption mppe 40
     vpdn group 1 client configuration address local hhyy
     vpdn group 1 pptp echo 60
     vpdn group 1 client authentication local
     vpdn username cisco password *********
     vpdn enable outside
     username cisco password 3USUcOPFUiMCO4Jk encrypted privilege 2
     vpnclient vpngroup cisco_vpn password ********
     vpnclient username pix password ********
     terminal width 80
     Cryptochecksum:9524a589b608c79d50f7c302b81bdfa4
