参数名 |
参数描述 |
默认值 |
OSD位置 |
OSD的起始位置 |
10 |
OPT选项 |
OPTION,详细说明附后 |
FC |
RCUT |
R CUT OFF 红截止 |
20 |
GCUT |
G CUT OFF 绿截止 |
20 |
BCUT |
B CUT OFF 兰截止 |
20 |
GDRV |
G DRIVE 绿驱动 |
40 |
BDRV |
B DRIVE 兰驱动 |
40 |
CNTX |
SUB CONTRAST MAX 副对比度最大值 |
7F |
BRTC |
SUB BRIGHT CENTER 副亮度中间值 |
50 |
COLC |
SUB COLOR CENTER FOR NTSC 副彩色中间值(NTSC) |
40 |
TNTC |
SUB TINT CENTER 副色调中间值 |
40 |
COLP |
SUB COLOR CENTER FOR PAL 副色度中间值(PAL) |
20 |
COLS |
SUB COLOR CENTER FOR SECAM 副色度中间值(SECAM) |
40 |
SCOL |
Cr input(#21) gain up,
000~111:0dB;1.1dB;1.9dB;2.5dB;3.0dB;3.3dB;3.6dB;3.9dB |
07 |
SCNT |
Y-SUB CONTRAST Y信号副对比度 |
0E |
CNTC |
SUB CONTRASRT CENTER 副对比度中间值 |
50 |
CNTN |
SUB CONTRASRT MINIMUM 副对比度最小值 |
01 |
BRTX |
SUB BRIGHT MAX 副亮度最大值 |
35 |
BRTN |
SUB BRIGHT MINIMUM 副亮度最小值 |
35 |
COLX |
SUB COLOR MAX 副色度最大值 |
7F |
COLN |
SUB COLOR MINIMUM 副色度最小值 |
00 |
TNTX |
SUB TINT MAX 副色调最大值 |
40 |
TNTN |
SUB TINT MINIMUM 副色调最小值 |
40 |
ST3 |
SUB SHARP CENTER NTSC3.58 IN TV副画质中间值(NTSC3.58 IN TV) |
25 |
SV3 |
SUB SHARP CENTER NTSC3.58 IN VIDEO副画质中间值(NTSC3.58 IN VIDEO) |
25 |
ST4 |
SUB SHARP CENTER OTHER COLOR SYSTEM IN TV副画质中间值(OTHER COLOR SYSTEM IN TV) |
25 |
SV4 |
SUB SHARP CENTER OTHER COLOR SYSTEM IN VIDEO副画质中间值(OTHER COLOR SYSTEM IN VIDEO) |
25 |
SVD |
SUB SHARP CENTER IN DVD |
26 |
ASSH |
ASYMMETRY – SHARPNESS 不对称 |
07 |
SHPX |
SUB SHARPNESS MAX POINTS FROM CENTER VALUE 副画质最大值 |
38 |
SHPN |
SUB SHARPNESS MIN POINTS FROM CENTER VALUE 副画质最小值 |
15 |
TXCX |
RGB CONTRAST DATA AT MAX DATA OF USER CONTRAST
OSD 对比度的最大值 |
1F |
RGCN |
RGB CONTRAST DATA AT MIN DATA OF USER CONTRAST
OSD 对比度的最小值 |
1F |
ABL |
ABL,详细说明附后 |
37 |
DCBS |
DCBS,详细说明附后 |
33 |
CLTO |
The data when TV mode & SOUND SYS != M 详细说明附后 |
0B |
CLTM |
The data when TV mode & SOUND SYS = M 详细说明附后 |
4B |
CLVO |
The data when YVU mode & SOUND SYS != M 详细说明附后 |
4B |
CLVD |
The data when YVU mode & SOUND SYS = M 详细说明附后 |
4B |
DEF |
0:V AGC reference,deends on YC Vcc;1:Depends on integrated regulator |
01 |
AKB |
00:AKB off;01:ACB(cutoff:align to targets);10:ADB(drive:align to targets);11:AKB(cutoff/drive:align to targets) |
00 |
SECD |
Secam mode |
18 |
HPOS |
50HZ HORIZONTAL PHASE 50HZ 水平相位(行中心) |
11 |
VP50 |
50 HZ VERTICAL PHASE 50HZ 场中心 |
03 |
HIT |
50HZ VERTICAL AMPLITUDE 50HZ 场幅度 |
20 |
HPS |
SHIFT DAT OF 50/60HZ HORIZONTAL PHASE 行中心偏移量 |
04 |
VP60 |
60HZ VERTICAL PHASE 60HZ 场中心 |
01 |
HITS |
SHIFT DATA OF 50/60 HZ HORIZONTAL PHASE 场中心偏移量 |
02 |
VLIN |
V-LINEARITY 场线性 50Hz |
08 |
VSC |
V-S CORRECTION 场S 50Hz |
60 |
VLIS |
V-LINEARITY 场线性 60Hz |
FF |
VSS |
V-S CORRECTION 场S 60Hz |
00 |
SBY |
SECAM B-Y |
08 |
SRY |
SECAM R-Y |
08 |
BRTS |
SUB BRIGHT |
00 |
AGC |
RF AGC ADJUSTMENT RF AGC 调整 |
30 |
HAFC |
1/2 AFC DATA ADJUSTMENT AFC调整 |
09 |
V25 |
VOLUME OUTPUT DATA AT 25% |
3F |
V50 |
VOLUME OUTPUT DATA AT 50% |
57 |
V100 |
VOLUME 100 |
7F |
MUTT |
Y-MUTE FOR SOFT START |
00 |
STAT |
CONTRAST UP FOR SOFT START |
00 |
FLG0 |
Flag0 |
52 |
FLG1 |
Flag1 |
04 |
REFP |
AKB Ref Pulse Position |
00 |
RSNS |
R SENS |
00 |
GSNS |
G SENS |
00 |
BSNS |
B SENS |
00 |
MOD |
00:akb CUTOFF SENSITIVITY,*9.75;01:*10.00;10:*10.25;11:*10.50; MOD.3:0 CUTOFF range:-0.65~+0.65;1:-0.65~+0.85 |
40 |
STBY |
Bit0,1:IF Standby; Bit2,3: VCD Standby |
00 |
SVM |
PIC1 SVM |
60 |
VBLK |
V BLANKING START AND STOP POINT |
00 |
VCEN |
V CENTERING |
27 |
HSIZ |
PICTURE WIDTH |
20 |
PRBR |
E-W PARABOLA |
20 |
TRUM |
TRAPEZIUM |
10 |
ECCT |
EW-CORNER CORRECTION(TOP) |
00 |
ECCB |
EW-CORNER CORRECTION(BOTTOM) |
00 |
EHT |
高压下尺寸的调整 |
24 |
UCOM |
00:GND;01:R OUTPUT;10:B OUTPUT;11:MONITOR RF AGC VIA ADC |
00 |
PYNX |
Normal H.SYNC max |
28 |
PYNN |
Normal H.SYNC min |
18 |
PYXS |
Search H.SYNC max |
22 |
PYNS |
Search H.SYNC min |
1E |
RCUTS |
RCUTS |
10 |
GCUTS |
GCUTS |
00 |
BCUTS |
GDRVS |
10 |
GDRVS |
GDRVS |
00 |
BDRVS |
BDRVS |
00 |
NOIS |
信号强弱界限设定 |
01 |
AKB_OPTION |
不起作用 |
00 |
AV_OPT |
详情附后 |
04 |
OPT2 |
详情附后 |
09 |
WAIT TIME |
开机等待时间 |
3F |
CUR_CEN |
拉幕位置 |
A5 |
CUR_STEP |
拉幕速度 |
01 |
PBRI |
连续按0键 图像所恢复的亮度数值 |
PCOL |
连续按0键 图像所恢复的彩色数值 |
PCON |
连续按0键 图像所恢复的对比度数值 |
PSHP |
连续按0键 图像所恢复的清晰度数值 |
PTIN |
连续按0键 图像所恢复的色调数值 |
PVOL |
unused |
AUSTP |
04 |
MODE0 |
详情附后 |
3F |
MODE1 |
详情附后 |
OSDF |
OSD频率 数值越大屏幕上字符越小 |
65 |
OPT参数
BIT |
FUNCTION |
0 |
Hotel mode 1:have welcome and no 0key 0:no welcome and have 0 key |
1 |
Real Time Clock 1:have real time clock |
2 |
V_Mute ON/OFF when CH changes(=1:ON) |
3 |
AUDIO GAIN SW of tb1240 |
4 |
Not VT Down of AFT when No Signal(=1) |
5 |
TINT 0:use 1:unused |
6 |
Select TV sync(0) or MONITOR sync(1) |
7 |
Mute of av switch key 1.use 0.no use |
ABL参数
BIT |
FUNCTION |
0 |
ABL-Gain 00:-0.2;01:-0.4;10:-0.6;11:-0.8v |
1 | |
2 |
ABL Start Point 00:-0.0;01:-0.15;10:-0.3;11:-0.45v |
3 | |
4 |
WPS 0:Y peak limiter off 1:Y peak limiter on,105IRE |
5 |
RGB ABCL 0:ABCL active for OSD 0:inactive |
6 |
1:计时收看清到20H;0:计时收看清到0H |
7 |
1:用户可按SLEEP键清除收看计时;0:不可 |
DCBS参数
BIT |
FUNCTION |
0 |
BLACK STRETCH 黑电平延伸
00:Off;01:Black stretch point,26IRE; 10 : 33 IRE; 11 : 43 IRE |
1 | |
2 |
Y GAMMA
00:Off;01:Y γ point 90 IRE,Gain –3dB; 10 : 82 IRE ; 11 : 75 IRE |
3 | |
4 |
OSD CONTRAST
00:80 IRE 01:70;02:60;03:50; |
5 | |
6 |
UNUSE |
7 |
BLK |
CLTO\CLTM\CLVO\CLVD参数
BIT |
FUNCTION |
0 |
Y Delay Time
000:-40 nsec;001:0;010:40 nsec;011:80 nsec;100:120 nsec;101:160 nsec;110:200 nsec;
111:240 nsec |
1 | |
2 | |
3 |
N Phase
00:USA(105 degree);01:Japan(93 degree);10:11:DVD |
4 | |
5 |
Color Y 0:Color gamma off ;1:On; |
6 |
PN-ID Sens 0:PAL/NTSC killer sensitivity,1mVpp; 1:10mVpp |
7 |
FID 0:Normal;1:Alwas killer off,i.e. always color on.. |
FLG0
BIT |
FUNCTION |
0 |
0:NORMAL;1:PIF over modulation switch on |
1 |
0:BPF;1:TOF |
2 |
0:Nyquist Buzz cancel,on;2:off |
3 |
Q det Gain |
4 |
L SECAM Mode |
5 |
SIF FIX Select 0:fix to normal, 1:control with sound system |
6 |
SIF 5.74 Select In D mode, aplly this bit to SIF 574 |
7 |
vco readjust when position select 0:disable;1:enable; |
FLG1参数
BIT |
FUNCTION |
0 |
CW SW |
1 |
YOUT ON |
2 |
HD input polarity select |
3 |
0:SIF beat down frequency,1MHz;1:+62.5kHz shift |
4 |
0:Sync separation level,40%;1:36% |
5 |
0:SIF 1MHz convert gain,Low gain;1:High gain for Evalution |
6 |
DET358 for Evalution |
7 |
C TRAP PASS for Evalution |
SVM参数
BIT |
FUNCTION |
0 |
SVM gain
00:-6dB;01:0dB;10:+6dB;11:+12dB |
1 | |
2 |
SVM DL(svm delay)
00:off;01:-100ns;10:-60ns;11:-40ns |
3 | |
4 |
CO MAX
0:cut off range is –0.65~+0.65 ; 1: cut off range is –0.65~+0.85 |
5 |
1:有计时收看功能;0:no the total time of watch TV |
6 |
1:有软换台功能;0:no the soft change channel |
7 |
UNUSE |
VBLK参数
BIT |
FUNCTION |
0 |
00:23H;01:33H;10:37H;11:41H (50Hz)
00:22H;01:30H;10:34H;11:38H (60Hz) |
1 | |
2 |
00:310H;01:299H;10:295H;11:291H (50Hz)
00:263H;01:254H;10:250H;11:246H (60Hz) |
3 | |
4 |
5 |
MODE0参数
BIT |
FUNCTION |
0 |
1:218频道;0:100频道 |
1 |
1:5060 (M制);0:两路AV (无M制时,几路AV用AV option来控制 ) |
2 |
0:有SECAM制;1:无 |
3 |
1:RGB Out-Cut Off DC;0:Y-MUTE |
4 |
1:有些屏显一直显示;0:有些屏显有时显示 |
5 |
0:ALPS\1:北松 |
6 |
SHOP OUT
00:DK;01:I;10:BG |
7 |
MODE1参数
BIT |
FUNCTION |
0 |
0:无BG;1:有 |
1 |
0:无I;1:有 |
2 |
0:无DK;1:有 |
3 |
0:无M;1:有 |
4 |
0:when asm & search,set up VCO adjust req. ,1:only power on
0:PIF VCO adjust trigger 1: normal (12 :bit 7) |
5 |
The algorithm of ASM. 0:ASM doesn't judge IFLOCK with case 4. 1:ASM judge IF LOCK with case 4 |
6 |
The algorithm of ASM. 0:ASM doesn't judge Fhsync with case 4. 1:ASM judge Fhsync with case 4 |
7 |
TINT polarity ,input to V/C/D. 0:normal 1:invert |
AV_OPT参数
Byte |
FUNCTION | ||
Video1 |
Video2 |
Video3 |
0 |
VIDEO |
DVD |
1 |
VIDEO |
S-VIDEO |
DVD |
2 |
VIDEO |
DVD |
VIDEO |
3 |
VIDEO |
S-VIDEO |
DVD |
4 |
VIDEO/S-VIDEO |
DVD |
5 |
VIDEO/S-VIDEO |
VIDEO |
DVD |
6 |
VIDEO |
DVD |
VIDEO |
7 |
VIDEO |
VIDEO |
DVD |
OPT2参数
BIT |
FUNCTION |
0 |
lunar calendar 1:have lunar calendar ; 0:no lunar calendar |
1 |
1:调整时间时不可以在电视机上显示 0:调整时间时可以在电视机上显示 |
2 |
1:只有英文 0:有中文 |
3 |
AV是否静噪;1:静噪;0:不 |
4 |
有无背景灯;1:有;0:无 |
5 |
No use |
6 |
No use |
7 |
No use一直设置为0即可。 |
MOD参数:
BIT |
FUNCTION | |
0 |
akb CUTOFF SENSITI VITY |
00:*9.75;01:*10.00;10:*10.25;11:*10.50 |
1 | ||
2 |
3 |
MOD.3:0 CUTOFF range:-0.65~+0.65;1:-0.65~+0.85 | |
4 |
000:无;001:45.75;011:38.9;100:38.0 | |
5 | ||
6 | ||
7 |
