一、Pix-Pix
[img]http://cisco.chinaitlab.com/imgfiles/2005.12.8.10.46.41.10.1.gif[/img]
PIX Central
Building configuration...
: Saved
PIX Version 6.3(3)
in terface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname pix-central
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
!--- This is traffic to PIX 2.
access-list 120 permit ip 10.1.1.0 255.255.255.0 10.2.2.0 255.255.255.0
!--- This is traffic to PIX 3.
access-list 130 permit ip 10.1.1.0 255.255.255.0 10.3.3.0 255.255.255.0
!--- Do not do Network Address Translation (NAT) on traffic to other PIXes.
access-list 100 permit ip 10.1.1.0 255.255.255.0 10.2.2.0 255.255.255.0
access-list 100 permit ip 10.1.1.0 255.255.255.0 10.3.3.0 255.255.255.0
pager lines 24
logging on
mtu outside 1500
mtu inside 1500
ip address outside 172.18.124.153 255.255.255.0
ip address inside 10.1.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
!--- Do not do NAT on traffic to other PIXes.
nat (inside) 0 access-list 100
route outside 0.0.0.0 0.0.0.0 172.18.124.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto map newmap 20 ipsec-isakmp
crypto map newmap 20 match address 120
crypto map newmap 20 set peer 172.18.124.154
crypto map newmap 20 set transform-set myset
crypto map newmap 30 ipsec-isakmp
crypto map newmap 30 match address 130
crypto map newmap 30 set peer 172.18.124.157
crypto map newmap 30 set transform-set myset
crypto map newmap interface outside
isakmp enable outside
isakmp key ******** address 172.18.124.154 netmask 255.255.255.255
no-xauth no-config-mode
isakmp key ******** address 172.18.124.157 netmask 255.255.255.255
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 1
isakmp policy 10 lifetime 1000
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:d41d8cd98f00b204e9800998ecf8427e
: end
PIX 2
: Saved
PIX Version 6.3(3)
interface ethernet0 auto
hostname pix2
names
!--- This is traffic to PIX Central.
access-list 110 permit ip 10.2.2.0 255.255.255.0 10.1.1.0 255.255.255.0
!--- Do not do NAT on traffic to PIX Central.
access-list 100 permit ip 10.2.2.0 255.255.255.0 10.1.1.0 255.255.255.0
pager lines 24
logging on
mtu outside 1500
mtu inside 1500
ip address outside 172.18.124.154 255.255.255.0
ip address inside 10.2.2.1 255.255.255.0
no failover
failover timeout 0:00:00
failover poll 15
no failover ip address outside
no failover ip address inside
pdm history enable
arp timeout 14400
no snmp-server enable traps
floodguard enable
crypto map newmap 10 ipsec-isakmp
crypto map newmap 10 match address 110
crypto map newmap 10 set peer 172.18.124.153
crypto map newmap 10 set transform-set myset
isakmp key ******** address 172.18.124.153 netmask 255.255.255.255
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
: end
PIX 3 Configuration
: Saved
PIX Version 6.3(3)
hostname pix3
names
access-list 110 permit ip 10.3.3.0 255.255.255.0 10.1.1.0 255.255.255.0
access-list 100 permit ip 10.3.3.0 255.255.255.0 10.1.1.0 255.255.255.0
pager lines 24
logging on
mtu outside 1500
mtu inside 1500
ip address outside 172.18.124.157 255.255.255.0
ip address inside 10.3.3.1 255.255.255.0
no failover
failover poll 15
pdm history enable
arp timeout 14400
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:aa3bbd8c6275d214b153e1e0bc0173e4
: end
