5I30 5I36和3I30工厂模式和EEPROM部分参数对照表
数值(十六进制) EEPROM地址(十六进制) 说明
固定值(以母片为准) [000] 校验地址
0x54,0x00 [072] HPOS 行中心位置,PAL/TV
0x3F,0x00 [074] PAL/RGB
0x3D,0x00 [076] NTSC/TV
0x5D,0x00 [078] NTSC/RGB
0xF7,0x00 [07A] HBST 行扫描起始位置,PAL/TV
0x57,0x01 [07C] HBSO 行扫描结束位置,PAL/TV
0x53,0x01 [07E] NTSC/TV
0xDF,0x0C [0BE] DSCV 检测线位置调整,PAL/TV
0xE5,0x0B, [0C0] NTSC/TV
0x3C [0D3] REF_CU 白平衡截止相关参考调节,PAL/TV
0x3C [0D4] REF_CUT_G PAL/TV
0x3C [0D5] REF_CUT_B PAL/TV
0x96, [0D6] REF_WD 白平衡驱动相关参考调节, PAL/TV */
0x96, [0D7] REF_WD_G PAL/TV */
0x96, [0D8] REF_WD_B PAL/TV */
0x8D,0x00 [0D9] VERT_P1 场位置及线性调节,PAL/TV
0x8A,0x00 [0DB] NTSC/TV
0xFB,0xFF [0DD] VERT_P 2 PAL/TV
0xFB,0xFF [0DF] NTSC/TV
0xDB,0xFF [0E1] VERT_P3 PAL/TV
0xDB,0xFF [0E3] NTSC/TV
0x37,0x05 [0E5] HOR_P0 行相关调节 PAL/TV
0xC7,0x04 [0E7] NTSC/TV
0x09,0x00 [0E9] HOR_P1 PAL/TV
0xF9,0xFF, [0EB] NTSC/TV
0xC5,0xFF [0ED] HOR_P2 PAL/TV
0xCA,0xFF [0EF] NTSC/TV
0xDF,0xFF [0F1] HOR_P3 PAL/TV
0x17,0x00 [0F3] NTSC/TV
0x52,0x00 [0F5] HOR_P4 PAL/TV
0x52,0x00 [0F7] NTSC/TV
0x11,0x19, [1DA] 16:9模式线性调整,PAL/TV
0x11,0x19 [1DC] NTSC/TV
以上是EEPROM中和生产相关的部分参数。5I30和3I30有可能根据实际情况做改动,
请在生产前参照EEPROM母片。
研发中心软件部 周民标
